Questions about headers
Old Mar 22, 2003 | 12:34 AM
nos4rot2's Avatar
Here is what I am wanting to do followed by a couple of questions. I would like to purchase hooker long tubes and either make or purchase a Y pipe (like mufflex). I know I will have to loose the cat that is under the manifold on the driver side Y pipe so can I get a simulator for it and keep the other cat that is after the collector in the Y pipe, or should I loose them both and get sims for both. I would like to keep at least one cat on there but I dont know if it possible to run just one on a two cat setup. I hope this makes sense. Thanks...
Old Mar 22, 2003 | 12:52 AM
NXz28's Avatar
not sure about running one cat on side of the y-pipe and no cat on the other side....but i'd get rid of both of them if you don't have to go through emmisions testing...
Old Mar 22, 2003 | 01:08 AM
jonaddis84's Avatar
What he said about losing them, what theyll do if you get one custom fabbed is throw a 3" hi-flow right behind where the two collect, or right next to the transmission, thats the best way to do it.
Old Mar 22, 2003 | 02:34 AM
nos4rot2's Avatar
Yea I was going to run the Y pipe off the headers and and then have the Y pipe go into one pipe right before the last cat. I dont have emission testing here so I guess I will get sims or have the O2 sensors programed out. Then I guess I can take the air pump off but what about the EGR can it be taken off or will it throw codes or anything?
Old Mar 22, 2003 | 02:54 AM
Dr.Mudge's Avatar
Program out those O2s or get O2 sims, or go OBD I, but running a cat on one side of the engine only sounds bad, even if it didn't effect the power balance that much, I still dont think it would be a good thing. If you really wanted to run a cat, then go for one and go OBD I, or if law requires in your state then just setup 2 cats, it has been done, similar to the FLP setup.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
