Question with weekend project
Old Jun 11, 2006 | 02:50 PM
BassProCamaro97's Avatar
Hey guys I'm lookin to finally do the headers on my 97 camaro. I'm lookin to see if i have everthing:
Headers
02 sims
02 extensions
ARP 1" header bolts
Fel-pro gaskets
Taylor OVC kit
SJM block off plates.
Is there anything i'm forgeting?
I know this has been posted a few times before, seein as I think i've searched them all at work this week. . I appreciate the help and if any of you have any tips for me that would be great.
Thanks guys~Jim~
Old Jun 12, 2006 | 06:51 PM
Re: Question with weekend project
Anyone?
Old Jun 12, 2006 | 07:20 PM
Kevin Blown 95 TA's Avatar
You might want to change plugs. Make sure you have some never-sieze, some dialectric grease. Tie wraps, maybe a few of the high heat insulating boots to protect any wires close to the headers so you don't get to do wires over again if you burn a couple up. You may want to squirt the bolts down with Liquid Wrench a day or two before to dissolve any rust. Maybe some other heat shielding for the heater box or starter motor. You might want mechanix gloves, maybe bandaids. Don't forget a shot of courage for whenyou reach that over-the-half-way-mark when you begin to have doubts and you just wish it was back the way it was before you started.
What are you using for a Y pipe? The stock one?
Old Jun 12, 2006 | 08:42 PM
Thanks for the reply.
No im planning on doing a true dual setup. Not sure yet if i want to go through and X pipe or if i should go straight pipes from the header.
Old Jun 13, 2006 | 12:38 AM
TobyZ28's Avatar
I'm in the same boat as you, a weeks away from the install though... Some thing which may/may not be tricky:
AIR fittings. Are you deleting the Air system? If so have the bolts ready, if not, be ready to wrench at em to get em off the stock maniflolds
I keep hearing the dipstick tube is a pain to do, have some sandpaper ready so you can grind it down a bit so it fits (This is just from some other posts, I have no idea how that part works yet lol)
Mechanics gloves for me will be a must... I've worked on my car enough to know that this job will have the potentially for a lot of blood loss
Have a good selection of tools too, it's always that 1 bolt which you can't quite get at at the right angle, that is always the cause of 80% of your time...
Good luck! Let us know how it goes
Old Jun 13, 2006 | 07:12 AM
Ya I'am deleting the air system as well as the egr. Im oredering the block of plates probably saturday from SJM. All the other parts I hope to have ordered by friday.
Ya I have all the neccesary tools. My uncles have a shop with a lift, air tools, and about a million other wrences and random things that i can use to get them in there.
Hopefully I can get some pictures of it as im goin along.
Thanks guys
Old Jun 13, 2006 | 12:49 PM
TobyZ28's Avatar
What kind of headers? Would you be able to snap some pictures of what the oil dipstick tube deal is? Haven't really found a post that explains whats going on very well to someone whos never done it
Old Jun 13, 2006 | 01:24 PM
I'm going to install hooker long-tubes. Ya hopefully i can get pictures every step of the way to help everyone who's never done it out. also to figure out what the heck goes where
Ill post the picks after i get the jub done. Probably a week or so.
Old Jun 13, 2006 | 01:49 PM
Sweetred95ta's Avatar
Good luck. The lift will come in hand. The car has to be pretty high up if you don't have one.
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 15, 2015 08:12 AM
