question on changing from non vented to vented opti....
Old May 23, 2005 | 10:45 PM
blackztpi's Avatar
I'm going to do a cam swap, and i will be converting to a vented opti in my 94. my question is... what is all involved in hooking up the vented optispark harnesses? I know i have to buy a vented opti harness, and i need to know if i splice this into some other wires or what? thanx
Old May 23, 2005 | 10:48 PM
Re: question on changing from non vented to vented opti....
There is no wire splicing. It connects just like the non-vented one. It's possible you might have to make a small "adjustment" to the connector shell where the harness plugs in up by the EVAP solenoid.
Old Jul 10, 2005 | 10:36 AM
screamin94Z's Avatar
shoebox, by "small adjustment" do you mean shaving the plastic piece inside of the connector? the vented harness has 2 alignment "pins" and the non vented only has the one.
Old Jul 10, 2005 | 12:32 PM
Yeah.
Old Jul 10, 2005 | 04:52 PM
SBHoney's Avatar
Is there any benefit to making the switch? I've heard the vented ones go bad too. I'm about 95% sure its my opti... Again!
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
CARiD
Jan 14, 2015 04:00 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
Jul 4, 2005 05:00 PM
