Question on the balancer/pully
Ok so i have my hub on the crank and the balancer on the ground. I need to instal it and was wondering, There is an arrow on it. Do i point the arrow in the same direction ans the hub mark (12 o clock with the motor at TDC)?
Re: Question on the balancer/pully
Yes, it will only fit like that.
The holes in the damper (its not a balancer) are not equally spaced, so it will only bolt on the hub one way.
Thank you. I never fit it up there to see that it only goes one way. Thants good to know thanks alot-Joe
