Question about longtubes and OBD2
Old Apr 18, 2003 | 02:45 PM
BriansZ's Avatar
I was considering getting in on the group buy for the jethot longtubes but wanted to know if I would have any problems with the OBD2 and no emissions. I realize I would have to buy O2 sims, that's not a problem. But will I throw a code without EGR or Air? I plan on doing heads and a cam down the road (next winter?), so I'd rather not have to flash the computer now and then have to do it again down the road. Also, I searched around and didn't find the answers I was looking for. Thanks!
Old Apr 18, 2003 | 02:50 PM
TransAm219's Avatar
You will have to get the computer re-programmed or else the car will have fits from what i understand
Old Apr 18, 2003 | 02:57 PM
tsleg's Avatar
So buy the headers now and install later when you do the heads and cam. That way you only have to reprogram once. Saves a bit of work, because you'd have to take them off later anyway.
Old Apr 18, 2003 | 03:17 PM
Brettinator's Avatar
why don't you just go ahead and hook up the EGR/AIR? get the LT's with the Air fittings. There is no performance gain from removing them, the EGR does not heat up the intake ambient air enough to make a difference. You will not throw a code that way. Depends too on your state emmissions. If they visual inspect for smog pump etc. If your goal is to lose weight and lose the air pump I guess that's a little weight but I still don't see the benefit of removing the EGR and messing with the PCM.
Old Apr 18, 2003 | 05:07 PM
BriansZ's Avatar
Thanks for the replies. Emissions aren't an issue for me. The vehicle is registered in Pennsylvania, but I live in Illinois (it's legal), so unless I move back to Pennsylvania I don't have to worry about that. I would buy them with the EGR/AIR but the group buy this time only has them without.
HectorM52
Jul 30, 2017 11:46 AM
WildRidez
Mar 27, 2015 08:22 AM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
