Question about comp 306
Old May 20, 2004 | 12:53 PM
67camaro02's Avatar
Quick question. I know a lot of you are running the comp 306 cam. Is it possible to run it in a stock head/piston LT1? I've always thought it was, but the tech guy at comp said no. Details below.
I ask because I bought a 383 stroker with KB -12cc pistons and stock/home ported heads running 10.5:1 compression with the hotcam in it. I want to throw the 306 in there for now untill next winter when I go custom grind and some AFR heads. I called the guy at comp to make sure the lift wasn't gonna be too much and slap a piston with the valve. He told me the 306 is not compatible with a stock LT1 and that the clearance is for me to figure out.
Well, before I pull the heads to check with clay and a micrometer and all that BS I thought I'd ask you guys. p.s. this will be with 1.6 rr's also.
Old May 20, 2004 | 01:09 PM
ibanez6rg's Avatar
You'll be fine.
Old May 20, 2004 | 01:13 PM
Spinner's Avatar
you'll be fine. piston to valve doesnt start becoming an issue until 60x lift and/or under a 112 lsa
67camaro02's Avatar
thanks for the back up. I thought I would be fine, but when numb nuts over at comp said it wouldn't work in a stock LT1 I got all paranoid and decided to double check everything. Thank you for the help
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
