Question about clutch install...
Old May 8, 2003 | 11:55 PM
94 CAMRO Z28's Avatar
Is the rubber boot that covers the shifter suppose to be glued down? I started getting into my clutch swap today and I couldn't even get the damn thing off! What should I use to get it off and do I need to be worried about tearing it? Thanks
Aaron
Old May 9, 2003 | 01:24 AM
96speed's Avatar
Cool Re: Question about clutch install...
Aaron
Its bolted down. 8mm I *think*.
Ryan
Old May 9, 2003 | 01:33 AM
Yes I know that, I took the bolts out, but it seems to be glued down too. Maybe the orignally owner put some rtv or something on it when he had it off for the shifter change.
Aaron
Old May 9, 2003 | 05:40 AM
RUFFIDLNZ's Avatar
Just get an end started and it should come up fine. I think mine was done like this too. It is some heavy rubber so I really dont think you will have a problem of ripping it.
Glenn
Old May 9, 2003 | 06:56 AM
Smoke T/A's Avatar
Re: Re: Question about clutch install...
Ryan
Actually they are 7 MM bolts. I would just pull it up or pry it up.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
