Question about cleaning cam bearings
Old Apr 13, 2005 | 05:59 PM
Beyonce Knowles's Avatar
I'm about to put my LE1 cam in, and I was wondering if it might be a good idea just to pour a couple quarts of oil down through the lifter valley and just let it flow through the cam bearngs, hopefully washing any debris that might have gotten in there out with it. I don't have any reason to think that dirt got in there, but better safe than sorry. Anybody see any problem here?
Old Apr 13, 2005 | 06:27 PM
Re: Question about cleaning cam bearings
I don't see how that is going to clean the bearings.
Old Apr 13, 2005 | 06:39 PM
Took a better look at it, wouldn't really effect the bearings. maybe if I put the oil pan back up there and used just filled the sucker to the top... But is there anything I should do before putting the new one in to clean things up? I took a look in there and everything looks clean as could be, no obvious knicks or anything, but I'm just paranoid.
Old Apr 13, 2005 | 06:56 PM
Pasky's Avatar
I would be more concerned in making sure the cam is clean before going in. Your better off pulling the motor and changing the cam bearings if your afraid they may be bad. Make absolutely sure you new cam is clean and wear some surgical gloves you can buy at autozone when applying lube to it.
Old Apr 13, 2005 | 07:08 PM
How should I clean it? Brakecleen?
Old Apr 13, 2005 | 07:10 PM
Pasky's Avatar
I got some deisel fuel and just doused it and took a soft non lint rag and wiped it down then sprayed it with carb spray. After that I lubed it up like a gay **** star and put it in.
Old Apr 13, 2005 | 07:17 PM
Would gasoline do the trick?
Old Apr 13, 2005 | 07:19 PM
Pasky's Avatar
Noooooo....
I used real diesel fuel but you can buy like "engine brite" from autozone, all that **** is diesel fuel in a can. That will work just as well.
Old Apr 13, 2005 | 07:23 PM
Where can I get a "lint free" rag?
Old Apr 13, 2005 | 07:25 PM
Pasky's Avatar
Autozone .
Old Apr 13, 2005 | 07:34 PM
looks like I gots some shopping to do. so much for doing it tonight.
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
