Question about Canton pan and sensor
I purchased a Canton 242T pan for my stroker motor Im building. And I am curious if the stock low oil sensor will still work on this pan or do I just delete it out?
Wrap the sender and the wiring harness with some heat tape. It will be CLOSE to the header if you're using long tubes.
And don't be suprised if the pan still needs clearancing. You probably will be OK with 3.75"(383) my 3.875"(396) needed more work.
I had to tap in the scraper plate a little to clear my rod bolts on the manley rods, but there bigger than most on the bottom end.
JasonD
Aug 23, 2010 03:14 PM
