question about AC compressor
so I broke my accs bracket and am taking it off. Ive got the power steering pump off, but do I have to take the compressor off. can i leave it on and let it come out with the bracket. If you have to take it off, do you have to take the pulley off, or can you get around all the bolts without takin it off. Also do you have to have a puller to take it off.
Three bolts on the front flange and 1 support bracket on the back will take it off. The top front is hard to see / easy to miss if the motor is dirty. I think you should be able to wiggle the accessory bracket around it and leave it in the car out of the way while replacing the bracket. You should not have to pull off the pulley / clutch to get it off.
stockssn2o
May 25, 2015 08:54 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
