question about 24lb svo????
i got a set of svo in my car know. when i got them they were used. one of them on the bottom piece thats holds the o-ring on (plastic tip) was broke. there was just a small piece gone. the plastic piece slid on fine and dosn't come off but i was wondering if that piece has any effect on how the gas flows??
also pcm forless said that the 24lb svo injectors flow 24lb at a different psi then stock 24lbs injectors? yes or no.
the SVO injectors are rated at 24 lbs, but at a lower pressure. That means on an LT1 rail designed for stock pressure, you will get more then 24 lbs/her.
LT1 pressure = 43.5
SVO pressure = 39.5
difference = ~5%
net rating for SVO injectors at stock LT1 pressure = ~25.5lb/hr
LT1 pressure = 43.5
SVO pressure = 39.5
difference = ~5%
stockssn2o
May 25, 2015 08:54 AM
