Question on 1.6 rockers on stock cam...
Old Sep 26, 2008 | 09:20 PM
JMG97SS's Avatar
I searched and couldnt find info for my question. Im looking to go ahead and put 1.6 roller rockers and springs on my car now and then later on add the cc305 cam. What would be a good roller rocker/spring kit for that? Im on a budget and need the best bang for the buck.
Old Sep 26, 2008 | 09:25 PM
IMHO, buy the springs you will use on the 305. That way you won't have to buy two sets and do the work twice.
Old Sep 26, 2008 | 09:43 PM
The_Bishop's Avatar
Echo what Shoebox said. Just did a valve spring swap tonight. While it wasn't the worst thing I ever did, I couldn't see doing it twice.
Old Sep 26, 2008 | 10:17 PM
deerslayinrenek's Avatar
can the valve springs be changed without pulling the head?
Old Sep 26, 2008 | 10:57 PM
JMG97SS's Avatar
I know they can with the use of a certain air tool to hold the valves up.
ok now what springs/rockers to use. Also to go to roller rockers i need studs too correct?
Old Sep 26, 2008 | 11:02 PM
Malice 1's Avatar
I just did the same thing you plan on doing. I recommend staying away from lunati springs. I have thier part #73943 springs, and 3 of them have snapped. They have less than 500 miles on them. I'm running a stock cam and 1.6 RR's.
Old Sep 26, 2008 | 11:15 PM
JMG97SS's Avatar
Well I found on Shoebox's site the info I needed I believe. One thing though, if you buy the spring kits that match the cam do you still need to check it with the height micrometer?
Old Sep 27, 2008 | 04:03 AM
krillformula's Avatar
Yea I think its important to check install height everytime you install a set of springs. My only exception might be if I installed a set of LT4 springs with the stock hardware. Otherwise I would check.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
thenewkid
Nov 27, 2014 09:41 AM
