Q? for those that put 94-95 MACS on a 97.
Old May 4, 2005 | 04:20 PM
lookingforwheels's Avatar
I replaced my cat with the staright piping that MAC sells and it has two holes for the bracket that used to hold up the cat. But my 97 bracket isn't long enough, everything is tight and the piping still sits way low, if I ordered a bracket off a 95 firebird would it be long enough? I looked up the parts in a parts catalog and the two brackets, both the 95 and the 97 looked identical but they are different part numbers. Any help would be appreciated.
Old May 4, 2005 | 06:14 PM
blackz97's Avatar
Re: Q? for those that put 94-95 MACS on a 97.
Take it to your local muffler shop, tell them whats up, they will weld something up that will work. It will get done quickly and cheaply if they are cool. Its too hit and miss with ordering the parts, the muffler shop should should just be able to weld on a longer bracket and or heat everything up and bend it so it doesnt sag.
Steve
Old May 4, 2005 | 06:34 PM
I guess I could try that, but nobody knows if theres any difference in the cat brackets b/t 95 and 97?????
Old May 5, 2005 | 10:20 AM
How about you 95 guys, when you installed yours, did your cat bracket bolt right up?
RUENUF
Mar 13, 2016 03:39 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
ChrisFrez
Feb 22, 2015 08:47 AM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Dec 27, 2014 10:06 AM
