putting in AC refridgerant
Old Jul 21, 2004 | 06:17 PM
huskersZ's Avatar
I have little to no refridgerant in my AC system. Since the thing has a low pressure switch, the compressor wont come on so I can put the stuff in. How do you get around this to make the comp. run so you can charge the system?
Old Jul 21, 2004 | 07:01 PM
VegasZ's Avatar
Re: putting in AC refridgerant
You have to jump out the compressor relay in the fuse box under the hood. There is a little schematic on the relay itself. Pull it out and use a short piece of wire to jump out the relay contacts.
Old Jul 21, 2004 | 07:08 PM
Mtrhds94Z's Avatar
Easiest way is jumping the underhood AC relay[not fooling with the pressure switch] Jump B1 to B4.. to run compressor.. [ bypassing pressure switch.. and PCM signal..]
http://shbox.com/1/hvac_compressor_control.jpg
help from shoebox site^^
Old Jul 22, 2004 | 09:21 PM
38oldz's Avatar
Just add 1 can of 134A the pressure swich should be happy. Low side press. should be about 30-40 psi at 2000 rpm
Old Jul 23, 2004 | 10:58 AM
HBHRacing's Avatar
don;t bother jumping anything... you can get enough freon in while teh car is off to short cycle the compressor when you turn it on. From there it will continue to take freon untill you have a full charge
Heathen1
Jan 2, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
