pushrods on a decked block
Old Apr 2, 2004 | 11:50 PM
my94blackz's Avatar
What pushrods should i run with a block that was 0 decked and im running the 233/239 cam with 1.6's, also the imapla head gaskets. Combo sent me stockers with the cam kit, the machine shop took off .027 on one side and .029 on the other. any sugestions.
Old Apr 3, 2004 | 12:21 AM
Dave88LX's Avatar
Only way to be sure is with an adjustable pushrod measuring tool.
Old Apr 3, 2004 | 12:22 AM
jhodel's Avatar
my block has been zero decked and I am putting the engine in the car with stock length PRs. They looked to line up just right on the valve stem. Also, I have 1.6 Comp cams Pro Magnum RR's and then had some clearance issues with the spring retainers. I needed to clearance the rockers with a Dremel tool and shorter PRs made that even worse. Oh, I have a 305 cam and Felpro .039 head gasket which gives a theoretical good qwench height (at least that's what I read...)
Jim
Old Apr 3, 2004 | 02:25 PM
my94blackz's Avatar
TTT
Quickss96
Jan 29, 2016 05:56 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
94Form
Jul 17, 2015 10:56 PM
