pushrod lifter and rocker combo information.
Old May 4, 2013 | 11:48 AM
  #31
slick1hunting's Avatar
Re: pushrod lifter and rocker combo information.
4th Gen LT1 F-body Tech Articles follow one of these methods
Old May 4, 2013 | 11:57 AM
  #32
i have done both the method 1 and method 3. Method one will require alot less work turning motor over and all that but takes a bit more concentration to adjust the right ones plus have to get to proper spot (tdc). Method 3 takes several rotations of engine but alot less paying attention lol. Also make sure to have the flat side of roller rocker that goes over the stud facing up(were the nut contacts).
Old May 4, 2013 | 01:45 PM
  #33
ussj4brolli's Avatar
I found one so far bad on pass side. Has an oval roller now. Cam feels perfect..
Still haven't figured pr length or Jack yet.. still trying to figure out how to. Hard to crank engine with just me and breaker bar with wp and everything attached...
Old May 4, 2013 | 02:08 PM
  #34
John95z28's Avatar
I knew I heard it. If the roller is oval there usually is some wear on the cam. Good luck
Example
The cam may feel smooth, but there will be two ridges on either side and the valve will not open as much. The distance of valve travel will be equal to the ridge depth.
Old May 4, 2013 | 02:53 PM
  #35
Example
I said ovaled not triangled LOL!
Does all the videos on YouTube pertain to my lt1 too? This is stupid LOL. Maybe I'm really nervous for nothing?
Old May 4, 2013 | 03:03 PM
  #36
John95z28's Avatar
Those vids are not really showing roller lifters so those details does not apply, but most of it is standard small block chevy.
Old May 4, 2013 | 03:24 PM
  #37
few things to help motor turn over( im sure your belt is off) second can pull a few plugs. be sure car is in neutral.
Posted from Camaroz28.com App for Android
Old May 4, 2013 | 03:52 PM
  #38
Not park? Checked geometry and it's the same. 7 turns on the comp cam checker so 7.15 correct. So nowSsummit for 7.15 trick flow hardened ones and then adjusting these things
Old May 4, 2013 | 04:43 PM
  #39
Bought.Trick Flow Specialties TFS-21407150 - Trick Flow® Chromoly Pushrods
I don't have guideplates though. Shouldn't be a problem right since my rockers are sa
Old May 4, 2013 | 06:23 PM
  #40
haha I forget not everyone has the m6. Everytime I forget to put in neutral and car rocks forward. I wouldnt think nuetral would help you but dont know. Mine turns pretty easy even with plugs in. Perhaps my torque wrench is longer that your cheater bar. I didnt use guideplates.
Old May 4, 2013 | 08:03 PM
  #41
This is the lifter. http://db.tt/ODNrapo9
I use a long torque wrench from orily.. weather turned to crap.. maybe tomorrow I'll finish it...
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
RX Speed Works
Oct 1, 2015 10:19 PM
kandied91z
Sep 30, 2015 11:43 PM
Z Power
Sep 19, 2015 11:19 PM
