Pushrod length question
For those of you using non-self aligning rockers and guideplates instead of the self-aligning rockers:
What length pushrod should I be using? Will the stock length work OK?
I am using Comp Pro Magnum 1.6 rockers. The head has been milled 0.030". The stock length is 7.200" (I believe). Comp recommends a 7.195" hardened pushrod in this case.
oldschool
Feb 9, 2016 09:21 PM
