Pushrod length
Old Jun 26, 2007 | 10:10 PM
69gto96z's Avatar
Pushrod length
Will my factory pushrods work with this set-up? GM b-body head gasket, .029 thick compared the f-body gaskets which are .039 thick, nothing milled off the heads or the block? So its only a .010 difference, and pushrods are sold in .050 increments.
Old Jun 27, 2007 | 07:48 AM
Revolutionary's Avatar
They'll work perfectly.
Old Jun 27, 2007 | 04:09 PM
2000GTP's Avatar
If you are ever in doubt, it never hurts to measure.
Old Jun 27, 2007 | 04:37 PM
Sweetred95ta's Avatar
This is the best advice. FWIW, I milled my heads .030" and used the Impala head gaskets and had no issues with the stock push rods.
Old Jun 27, 2007 | 05:26 PM
69gto96z's Avatar
I will probably just re-use em, the motor is out of a 94, so they are hardened pushrods.
Old Jun 27, 2007 | 09:41 PM
Z-RATED94's Avatar
Mine where mill .010 and used the Impy gasket, had to use 7.15 pushrods. Rick
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
