Pushrod length
Old Jun 27, 2004 | 07:19 AM
Jeff95TA's Avatar
Pushrod length
Anyone that's had heads done by Lloyd (or anyone else) - should I expect stock pushrod length to be correct? I know you're supposed to check the pushrod length (and I'm going to), but has anyone actually done it? I see pushrods offered in stock length and shorter, but what if the length falls somewhere in between?
Old Jun 27, 2004 | 08:29 AM
slopokrodrigez's Avatar
Use your stock rod to check length according to this guide from Comp Cams.
http://www.compcams.com/Technical/Cu...ML/306-307.asp
From there you can determine what length checking rod you need. Chances are good you will not need a different length rod.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
