Pushrod help needed
Old Dec 8, 2003 | 05:39 PM
SnakEaterZ28's Avatar
Pushrod help needed
Hey..I bent the hell outta my old pushrods.... DO i need to spend all the cash to get chromemoly or will some regular hardened ones do???? All i have is the hotcam kit...So i have nothing too radical... But any help would be nice. Thank you
Old Dec 8, 2003 | 05:53 PM
llafro's Avatar
The real question is qhy you bent the pushrods in the first place. There is no reason why the pushrods should have bent in the first place absent major problems or serious over-revving. Are you getting coil bind or is the valve lash set wrong?
In the end, the answer is that yes you can just get replacement pushrods. You only need hardened ones if you are using guideplates, which shouldn't be the case with the hotcam kit.
Old Dec 8, 2003 | 06:01 PM
Oh..i bent them cause i am a idiot and didn't adjust my rocker arms right when i installed the cam...and they are all bent up because of that! Cause i tired to start it and they were way to tight..i8'll hafta take a picture of them...they looks like S's
Old Dec 8, 2003 | 06:43 PM
gb95zconv's Avatar
Ive got a set of hardened ones Ill sale ya for $20 shipped.
Old Dec 8, 2003 | 06:48 PM
AsianSensation's Avatar
I'm using hardened pushrods without guide plates. You'll need 7.200" long.
http://www.thunderracing.com/index.c...yid=1107#T1555
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
