Pushrod guideplate wear...is this bad? (pics)
Old May 22, 2004 | 12:00 AM
PoorMan's Avatar
Today I removed the stock rocker arms to install my 1.65 rr's and found that my stock pushrods seem to be rubbing the guideplates. I am running guideplates (unknown brand, installed by Llyod) and stock 94 pushrods which are said to be hardened. They have the hardness test dimple on them btw. Anyway, a couple look as though they are rubbing on side of the guideplate pretty good.
http://community.webshots.com/photo/...45057644bAeqmb
http://community.webshots.com/photo/...45057387UYxlXZ
I am unsure if this is normal wear or not. The wear is not smooth. It's pretty rough and pitted in some places. If it's not normal then I think it may be caused by either:
1. Using SA stock stamped rockers with guideplates
2. Using non GM guideplates on an LT1 head
3. My stock 1994 pushrods are not hardened "enough"
I don't know what I need to do. I am installing my new NSA 1.65 RR's along with GM guideplates just to narrow what "I think" it could be. Anyone have any suggestions?
And just to make one long thread; does this look like my stock pushrods are now too long? The head was milled 0.010 and I am using the Felpro gaskets.
http://community.webshots.com/photo/...45058113LMBYut
I had to use a Crayola marker so it's not the best wear pattern. Should I buy new pushrods? Maybe 7.150"? The wear pattern is just south of the center line. I am not sure on this either.
Thanks for the advice guys
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
cmsmith
Mar 16, 2015 02:34 PM
Catmaigne
Dec 25, 2014 12:16 PM
