Push Rods lengths different?
Old Sep 7, 2007 | 12:22 PM
ricoace's Avatar
Hey Guys
I believe I may have done something very stupid
Are the push rods for the intake and exhaust valves on a LT1 different lenghths ... I have just finished rebuilding mine and I have been having problems adjusting my valves...its no matter how i do the adjust hot or cold ...the end result is a crappy idle.
I was told by the guys that did my block prep that since the lifters are new, it didnt matter if I keep the rods in order?????
any suggestions would be helpful
Old Sep 7, 2007 | 12:23 PM
Stock pushrods are all the same length. 7.200"
Old Sep 7, 2007 | 12:40 PM
dangalla's Avatar
what do you mean by a crappy idle and what makes you think its an issue with mis-adjusted valves
also some info on the build might be a good idea, because it does not sound like the 100% stock vehicle you have in your sig
Old Sep 7, 2007 | 02:28 PM
ricoace's Avatar
AT first start up (break in) Idling was eratic. I loosened the rocker nuts alittle and a great improvement was the result. Put a OBD1 computer on it and everything (but the idle) is running within parameters, no codes. Could it be something else like fuel, possibly, but I have to run with the fact that loosening the rocker arm nuts improved my idle ...alot!
Ive adjusted these valves on this car before after a head job and did it perfect...so , i am quickly fading on the fact that my valves are just out of adjustment...just want to eliminate everything first.
And , yes, this car has no modifications whatsoever. other than OEM replacement parts...stock engine.
Thanks for your inputs
Old Sep 7, 2007 | 02:44 PM
ZL1modified's Avatar
how much preload... with new stock lifters i would go the 1 1/4 turns and see if that helps...
Old Sep 7, 2007 | 04:33 PM
ricoace's Avatar
I will try it ...thank you
Old Sep 7, 2007 | 04:42 PM
BUBBA's Avatar
Actually 1 1/4 might be a tad too tight. I believe factory recommendation is about 1 turn----most go no more than 1/2 turn, but if it is too noisey you might try to tighten them a tad more to see if they quite up some. JMHO
Old Sep 7, 2007 | 06:59 PM
dangalla's Avatar
yeah 1 1/4 imho is too much, start off at 1/2
Devinfoote87
Feb 12, 2016 03:21 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
mrwz28
Jul 8, 2015 09:11 PM
