Pulling heads due to blown head gasket
Old May 24, 2003 | 06:58 PM
npaulseth's Avatar
Is there anything else I should do while I have the heads off? I am going to put on Imp. SS gaskets. Anything else that might be worth while when the heads are off? Thanks. Noah
Old May 24, 2003 | 07:03 PM
Rodrigues's Avatar
rockers/bigger valves/ported heads/cam/springs...
Old May 25, 2003 | 10:24 AM
npaulseth's Avatar
haha, ya. I actaully was going to, but I was just laid off, so that went down the tube. Thanks though.
Old May 25, 2003 | 12:07 PM
Fuels94TA's Avatar
There is so much to do, but since your laid off it's hard to get some of these mods knock out all at once. New plugs/wires, valve job with new springs and retainers, 1.6 RR, Hot tank the intake manifold and remove all that build up of carbon, clean/flush the injectors, clean the piston tops of carbon build up, clean the up TB also. There are some but it's all what you want to do.
Vinny
Old May 25, 2003 | 01:16 PM
npaulseth's Avatar
thank you much
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
