Pulling the front end up with 3.42's??
Old Apr 18, 2004 | 07:17 PM
"White Knight"'s Avatar
Alright i still haven't decided what gear to get. I have decided it's time to save for the Moser 12 bolt though.......that i am sure of....i just need to decide what gear to get.
I was wondering how much hp you think would be needed to pull a full weight Camaro do wheel-stands? Assuming all the suspension work has been done?
500rwhp?,600rwhp?, more?
Old Apr 18, 2004 | 07:47 PM
Spinner's Avatar
With slicks/skinnies I've seen it done with under 300 rwhp. But that barely pulled the fronts off the ground. 500 rwhp and a real good suspension/slicks will make for a good wheelstand.
Old Apr 20, 2004 | 01:56 PM
was that with 3.42's? That is awesome if it was under 300 with 3.42's. I want to be able to pull the whole front straight up(as in need wheelie bars) am am thinking 650rwhp should do it
Old Apr 20, 2004 | 02:49 PM
RE AND CHERYL's Avatar
WHY??
Even if you had an engine capable and enough traction to do so, what good would it do? I would rather keep the front end down as much as possible for maximum acceration.
Your not thinking about showing off on the street, are you???
Old Apr 20, 2004 | 03:11 PM
LT1Squirrel's Avatar
you could probably do it with a stock motor..but you need to go hardcore on the suspension and weight reduction....4:56's or bigger wouldnt hurt
grabbem88
Feb 23, 2015 09:41 PM
dbrockma
Feb 16, 2015 02:56 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
