Pulling engine, need help on a connector
Old Feb 23, 2008 | 07:26 PM
12sec97Z28's Avatar
Does anybody have a picture of the connector that goes into the oil level sensor bolt? I'm trying to unhook it, but I don't want to break the clip. Or can somebody explain how it connects?
Old Feb 23, 2008 | 08:14 PM
greenmachinedriver's Avatar
are you talking about the plug that goes into the sensor itself? if so there should be one side open where the conector tab is that you can use a pocket screwdriver to unclip the conector. sorry it is dificult to explain without a picture reference.
Old Feb 23, 2008 | 08:28 PM
jchevy's Avatar
It looks just like the IAT sensor clip doesnt it? Same type of plug.
Someone verify
Old Feb 23, 2008 | 08:37 PM
AHARTZ28's Avatar
its a 2 wire connector the IAT has 4 i believe. it looks like the evap connectors on the pass side of the intake. usually white and black
Old Feb 23, 2008 | 08:46 PM
12sec97Z28's Avatar
Someone verify
This is what I needed to know. Some clips you have to push down on and some you pull up on. I know it's probably a little brittle, so I don't want to yank too much on it and snap the retaining clip. I'll check out the IAT. Can anybody verify that it pulls up like the IAT?
Old Feb 23, 2008 | 08:50 PM
jchevy's Avatar
Just verify first! Im going off memory
Old Feb 23, 2008 | 09:56 PM
Ken95Z28's Avatar
The connector needs to be pulled up, use a screw driver to release it.
Old Feb 24, 2008 | 10:19 AM
jclark311's Avatar
Its a pull up, i just did mine. be carefull, its brittle.
Old Feb 24, 2008 | 02:56 PM
12sec97Z28's Avatar
Thanks all. I love this damn forum!
Richardan15
May 30, 2015 08:36 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
