pulleys
Old Aug 28, 2005 | 11:38 PM
LT193's Avatar
pulleys
anyone know how i can remove the AC and still have a pulley belt that works for my 93 Camaro Z28. Maybe something without the power steering aswell?
Old Aug 28, 2005 | 11:44 PM
Re: pulleys
You can substitute the GM a/c delete pulley p/n 10115875 for the a/c. You will have to get more creative to delete the p/s.
Old Aug 28, 2005 | 11:45 PM
LT193's Avatar
Re: pulleys
Thanks man, i found a manual rack and pinion. Although i guess ill still have to rout it all somehow lol. Do you know how heavy this delete pulley is? Thank you for your quick reply :]
Old Aug 29, 2005 | 05:09 PM
Re: pulleys
The A/C delete pulley has a very low weight..... maybe a pound or so.
If you are deleting the A/C and the power steering, you would be wise to relocate the alternator below the engine, get the brackets to do this from either SJM Manufacturing or Madman Racing. That way you have also deleted the tensioner, and need only a short belt from the crank pulley to the alternator.
Old Aug 31, 2005 | 08:10 PM
LT193's Avatar
Re: pulleys
thanks so much, i just ordered that delete pulley from summit he recomended. When i can save for a manual rack ill do what you suggest. Thank you for all of your help!!
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
