pulley help
Old Jun 2, 2004 | 09:29 PM
pyrojoex28's Avatar
pulley help
im replacing my opti, so i need to get off the crankshaft pulley. ive got the 3 bolts off, but my dad insists there is one in the middle i have to take out. it just spins when i try to put something on it though. does this come out, and what size is it actually? i have a pulley, but the bolts are too big for it. what else can i do?
Old Jun 2, 2004 | 09:32 PM
LPEdave's Avatar
The last one in the center is holding on the hub, you're not wanting to remove that. So the three bolts around the circumfrence of the damper are all you need to remove to get it off. Just make sure when you're pulling off the damper that you're not also pulling on the hub, as it's not coming off...
Dave
Old Jun 2, 2004 | 11:20 PM
If the pulley is really stuck, you might need to use a puller.
Old Jun 3, 2004 | 12:33 AM
OBE1 95Z28's Avatar
To state it another way, the pulley (round disk that the belt rides on) needs to come off and only the 3 bolts hold it in place. The hub (behind the pulley, looks like a "Y") can remain in place to remove the opti. It does have a center bolt but it doesn;t need to be removed. Once the pulley is removed, the hub can be rotated to clear the opti.
Old Jun 3, 2004 | 07:59 PM
pyrojoex28's Avatar
holy crap, i just tried using a puller on it. had so much pressure i could barely turn it anymore, but it doesnt look like its budged at all. i doused it with liquid wrench before i tried.
anything else i could try?
Old Jun 3, 2004 | 11:19 PM
You are just trying to remove the pulley, right? Did you use a puller like in the link I posted? If the puller is not centered, it will bind the pulley on the front of the hub and it might not come off.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
