pulley help
pulley help
im replacing my opti, so i need to get off the crankshaft pulley. ive got the 3 bolts off, but my dad insists there is one in the middle i have to take out. it just spins when i try to put something on it though. does this come out, and what size is it actually? i have a pulley, but the bolts are too big for it. what else can i do?
The last one in the center is holding on the hub, you're not wanting to remove that. So the three bolts around the circumfrence of the damper are all you need to remove to get it off. Just make sure when you're pulling off the damper that you're not also pulling on the hub, as it's not coming off...
Dave
Dave
To state it another way, the pulley (round disk that the belt rides on) needs to come off and only the 3 bolts hold it in place. The hub (behind the pulley, looks like a "Y") can remain in place to remove the opti. It does have a center bolt but it doesn;t need to be removed. Once the pulley is removed, the hub can be rotated to clear the opti.
holy crap, i just tried using a puller on it. had so much pressure i could barely turn it anymore, but it doesnt look like its budged at all. i doused it with liquid wrench before i tried.
anything else i could try?
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
