pulley
Re: pulley
personally i thought the hardest part was getting the old pulley off. The pulley remover i rented from autozone didnt work very well IMO. The belt was a little hard to put on also, but with some force it will go on eventually.
Re: pulley
I installed the March 2-pulley UD. Had to use an impact wrench to remove and install the nut on the alternator pulley because it tend to turn when you use a regular wrench.
The March UD came with special sized belt. Even though the schematic for installing the belt in under the hood, take a good look at it before you remove it. You will, of course need to loosen the tensioner first. JMHO
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
