PTV Clearance - Pushing the Limits??
Old Jun 10, 2009 | 02:10 PM
ThreeHonks's Avatar
Im in the process of building my motor and am going with about 11.4:1 compression. I just need to make sure that I will not be running into any issues with PTV clearance.
Specs of my motor:
Stock deck height (.015")
Mr. Gasket .026" compressed height head gaskets
Speed Pro 4.030" Forged Pistons with stock style 4 valve reliefs (+6.10cc)
Milled heads down by .020"
The cam I am using is a custom grind by L.E. 234/238 .565"/.565" on a 112 LSA
So will I be screwed by having the heads milled?
Old Jun 10, 2009 | 02:44 PM
RUDEDOG's Avatar
You should be ok but you need to check anyway. I don't think the .020" off the heads is going to be a problem. I used a cam slightly smaller than that and .039" head gaskets and had about .250" PTV. I didn't measure exactly since I had so much clay left.
Old Jun 10, 2009 | 03:09 PM
ThreeHonks's Avatar
I will be claying it when it gets put together but I jsut wanna make sure that it will be in the range. I know its impossible to tell me plain yes or no but I need to make sure that it SHOULDNT be a problem
Old Jun 11, 2009 | 07:10 AM
DAVE00's Avatar
Specs of my motor:
Wouldn't stock style heads with VR's yield -5cc as they are in essence flat tops?
+6.10cc would tend to tell me these are domed pistons to raise the comp.
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
