Prothane or energy suspension poly motor mounts?
Old Jan 11, 2004 | 09:13 PM
$hawn's Avatar
Has anyone had experience with both of these brand of motor mounts? Is one softer or harder than the other, the prothane ones are slightly cheaper, which ones would you run? Thanks
Old Jan 11, 2004 | 11:04 PM
S.J.S.'s Avatar
I run the energy suspension ones and think they're great. Just built my motor so I couldn't tell ya the difference but I like them.
Old Jan 12, 2004 | 10:11 PM
$hawn's Avatar
So whos got the prothane ones, i'll prolly go with those. Thanks for your input s.j.s.
Old Jan 13, 2004 | 12:25 AM
Red_94Formula's Avatar
i also run the ES with no problems. i dont think anyone would have a prob with either. they are pretty simple
Old Jan 13, 2004 | 01:08 AM
RedPhenx's Avatar
Is this a daily driver?
if so, read this:
http://www.geocities.com/MotorCity/1701/bushings.htm
Old Jan 13, 2004 | 05:25 AM
QCKZ28's Avatar
ES brand or poly brand, i would be you wont be able to tell the difference between the two.
now there is a difference between rubber and poly.....
jesse
Old Jan 13, 2004 | 07:46 AM
Type_O_Negative_1320's Avatar
I've been running the Prothane mounts since September on my daily driver and they seem fine. There's a little more vibration than with the rubber mounts, but I'm used to that anyways.
Old Jan 13, 2004 | 08:04 AM
94camarof1's Avatar
energy suspension makes good products
Old Jan 13, 2004 | 08:22 AM
Hyperspeed97z28's Avatar
I'm sure they are pretty much equal, I just got some Energy Suspension Poly motor mounts.....
Old Jan 13, 2004 | 10:02 AM
rocmemphis's Avatar
Prothane on my car. Car does vibrate a little more but the whole front end feels much tighther. You will like them but you will not like the install
Old Jan 13, 2004 | 11:23 AM
Chrisbequick's Avatar
if so, read this:
Motor mounts are not a suspension part.
-Chris
Old Jan 13, 2004 | 09:06 PM
$hawn's Avatar
I think i'll go with the prothane ones and if I dont like em i'll get some factory replacments. I wouldnt think there would be a big difference between the two, but I was just curious if anyones used both. I have the es tranny mount so i'm used to some vibrations, and I only drive it a few days a week. Thanks for the input everyone.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
DropTop91
22
Aug 8, 2002 10:53 AM
