Pros and Cons of programming out O2 sensors?
Old Mar 17, 2005 | 04:07 AM
cmking26's Avatar
I had MadZ28 program out my o2 sensors but I am wondering if thats a good idea. I did it because one of them wasn't working. Should I buy a new one and have computer changed or what? I need pcm done for new gears anyway so thats no biggie.
Old Mar 17, 2005 | 04:49 AM
disco192's Avatar
Re: Pros and Cons of programming out O2 sensors?
Well, it is hard to pass emmisions w/o o2 sensors. It will run just fine w/o oxygen sensors. Alot of times, with a big cam, you will get added cam surge w/ o2 sensors.
Old Mar 17, 2005 | 06:55 AM
cmking26's Avatar
No emissions here. What exactly do o2 sensors do then?
Old Mar 17, 2005 | 07:25 AM
teke184's Avatar
how is your car calculating a/f ratios if you have no O2 sensors??
Old Mar 17, 2005 | 07:29 AM
1-bad-z28's Avatar
that is what i was thinking. I understand that it will make the computer think they are there and right on the money but what if you are running a little rich or lean? The computer will think everything is fine and not adjust as needed. Right? Don't sound like a good idea to me.
Old Mar 17, 2005 | 07:36 AM
BlkLT1Z28's Avatar
The front O2's do the job of keping the motor running rich or lean. All the rear are there for is to make sure the cats are doing there job. When the comp starts seeing that the front O2's are reading the same as the rears it turns on you CEL b/c the comp thinks the cat is bad or not there.
Old Mar 17, 2005 | 07:41 AM
Kataklysm's Avatar
Haha get them put back in man. O2 sensors are what sends the PCM the readings of oxygen in the exhaust stream during open loop, without them sending the info the car is either going to run how it wants, rich or lean. I don't know why you would take them out, if one isn't working replace it.
Old Mar 17, 2005 | 07:46 AM
BlkLT1Z28's Avatar
Yes, you need your front ones, I though we were talking about the rears. A new one is only like $40
Old Mar 17, 2005 | 07:56 AM
His sig says 1994, so he has no rear O2s.
Old Mar 17, 2005 | 08:00 AM
1-bad-z28's Avatar
I think it is closed loop. Yeah you don't need the rear ones, only the front ones.
Old Mar 17, 2005 | 09:11 AM
Destructo's Avatar
If i'm going to be putting LT headers on a 97 Z28, i only need the front 02 sensors then? I just want to make sure. Should i then get 02 sims for the back two? Thanks in advance
Old Mar 17, 2005 | 10:34 AM
Kataklysm's Avatar
Yes you need the fronts but you can add sims for the rears.
Old Mar 17, 2005 | 12:00 PM
LPEdave's Avatar
I would check with MadZ28 to make sure you know what he really did. I find it a bit hard to believe he programmed out the use of O2 sensors in your case. I bet it was more like you filled out a standard form, which had a checkbox on it for programming out rear O2 sensors (which would make sense on a newer car). But yes, get your O2 sensor replaced either way
Dave
Old Mar 17, 2005 | 03:22 PM
cmking26's Avatar
Im pretty sure he programmed it to run open loop constantly. I thought it was running rich so I will definitely get new sensor and have it put back in pcm. Thanks for all the help.
Old Mar 18, 2005 | 08:16 PM
slp223's Avatar
it would be programmed to be in open loop. you car runs in open loop when you first start it up and when you are at wot. I open loop you just have preset parameters and the 02 don't adjust anything.
