Pro's & Con's of the AFR 227
Old Sep 21, 2004 | 10:40 PM
Schurters LT1's Avatar
Looking to put these heads on a 383 What is the....Good,the bad , the ugly with the AFR227 head .
This car will be a DD car and i want a head that i can grow with...
-order the head from who
-should i get AFR's port work or order them bare and get someone to clean them up
-how small can you get the cc
-any wild part need
-who is runing these heads
thx
Old Sep 22, 2004 | 03:35 AM
z28ss96's Avatar
Re: Pro's & Con's of the AFR 227
You should talk to the guy's at AFR. However, there's are some valve train issues that need to be looked at. I believe you need offset lifters/rockers as well as a few other things. The AFR 210's are the largest you can go without valvetrain modifications. If the car is a daily driver I wouldn't recomend 227's, you won't have the low end for the street unless your blown or have a turbo. I talked to the guys at AFR a couple of years ago so I don't remember all the details. I hope this does help.
G-BODYT56
Jan 14, 2022 11:14 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
