proper way to bleed air with electric water pump
Old Feb 3, 2004 | 10:11 PM
WhoomWhaatWhaah's Avatar
I got an electric water pump and now i'm confused on how to bleed the system?
Old Feb 3, 2004 | 11:01 PM
Heatmaker's Avatar
Advanced Member
You bleed it the same way you bleed the old system. By the bleeder screws connected to the Hoses attacthed to the WP housing.
Old Feb 4, 2004 | 01:56 PM
llafro's Avatar
You can just turn on the pump and them open both of the bleeder screws. When you get only coolant, then you're fine. It works great, since the engine doesn't have to be running.
BRAD
Old Feb 4, 2004 | 04:40 PM
great, so now I can bleed with the engine off. Will the thermostat open?
Old Feb 4, 2004 | 04:55 PM
ibanez6rg's Avatar
Or with the radiator cap.
Old Feb 4, 2004 | 07:18 PM
Mtrhds94Z's Avatar
No it won't as it's temperature operated[160[or stock @180] opens it...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
