Proform rockers
Old Dec 15, 2008 | 12:28 AM
mrl510's Avatar
Proform rockers
What do yall think about proform roller rockers i was looking at buying some of them? I just havent heard alot about them thanks alot.
Old Dec 15, 2008 | 06:40 AM
Most of what I have heard is bad (like most Proform products). Seen several threads where they have worn excessively.
Old Dec 15, 2008 | 10:28 AM
mrl510's Avatar
ok thanks for the input
Old Dec 15, 2008 | 10:39 AM
Have you done a search on this forum? I think you might find some threads about Proform rockers.
Old Dec 16, 2008 | 12:17 AM
goldmecham's Avatar
my bud had them on a lt4 hot cam and the SA disk broke and the rocker came off the spring and put tons of metal in the oil pan. we had to rebuild the motor.
Old Dec 16, 2008 | 02:12 AM
bombebomb's Avatar
I have heard they're bad also. I would not buy them.
Old Dec 16, 2008 | 04:43 AM
87bandit's Avatar
I'd rather run a roller tip rocker like the comp magnum 1.6 that I know is a quality product for the same price than a junk brand full roller
Old Dec 16, 2008 | 11:46 AM
marshall93z's Avatar
I ran them for 50,000 miles with no problem whatsoever. Another friend of mine has them on a supercharged engine making 550rwhp with no problems. He has ran them for years, too.
Old Dec 16, 2008 | 11:43 PM
94Firehawk161's Avatar
I know someone who has run them for about a year now with a CC306 cam with no problems. Just make sure that if you are using them with a set of heads that have EVER been off the car, that you check the clearance between the self aligning discs and the valve retainers/locks. Inadequate clearance between these is usually the cause of most self aligning disc problems and can cause severe valve train failure.
Old Dec 17, 2008 | 11:50 AM
texas97z's Avatar
I ran the proform 1.6's with a hotcam in my old 355TPI car for a year and didn't have any problems. Not saying good or bad just my experience. I've also had luck with the one out of the hot cam kit, currently using them on this car with no problems. Maybe consider them as an alternative. Usually can find some for a decent price used. Just a thought.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
