Problems with Trick Flow Elbow w/ SLP CAI
Old May 23, 2005 | 08:16 AM
akrott1's Avatar
Question Problems with Trick Flow Elbow w/ SLP CAI
Has anyone else had any problems with the fitment of the Trick Flow Elbow with the SLP CAI? When I tried to install my elbow, it appears that it is approximately 1/4" too long on the MAF side of the elbow. I was thinking about just trimming the excess off the elbow, but there is a small ridge running around the end of the elbow that would get cut off. I am assuming that if I tighten the clamp adequately that the missing ridge would not be a problem. Any thoughts on the matter?
Aaron
Old May 23, 2005 | 10:58 AM
jim88iroc305's Avatar
Cool There is definately fitment issues for Trick Flow Elbow w/ SLP CAI
I remember reading a while ago about how some had to trim the SLP tube or the TF unit for proper fit.
I remember that it didn't fit with an SLP CAI I had but was fine with an AS&M CAI I had so i sold the SLP.
Do a search and see if you can find the posts I'm referring to. Over a year ago should be the ones I'm talking about.
Old May 23, 2005 | 03:05 PM
DiabloGT's Avatar
Re: Problems with Trick Flow Elbow w/ SLP CAI
damn so am i gonn ahve to do that if i get the trickflow elbow? because im about to get one with my slp cai...
Old May 23, 2005 | 03:26 PM
fastcamz28's Avatar
I have the Trick Flow elbow w/ the F-1 (same as SLP) CAI and it fit w/o trimmimg anything but was very tight. It is a real chinese puzzle to install and I suspect I do it different every time.
http://www.extreme-z.com/appearance/...small_DSC_6765
http://www.extreme-z.com/appearance/...small_DSC_6762
Old May 23, 2005 | 04:09 PM
DiabloGT's Avatar
where do u buy that chrome altenator? do u have any link?
Old May 23, 2005 | 04:17 PM
fastcamz28's Avatar
It's a kit and I just replace the oem cover when I have to replace the alternator. I will have to look the vendor up when I get home (saved in my Favorites!).
Thanks!
Old May 24, 2005 | 11:34 AM
DiabloGT's Avatar
Thanks!
did you get the link yet?
thanks
Old May 24, 2005 | 12:30 PM
akrott1's Avatar
You thread stealers! (LOL)
I just cut about 3/8" off the MAF end of the Trick Flow Elbow. Hopefully it works alright since I won't be returning it now!
Good luck with the alternator covers boys....By the way they have them at Summit Racing for $59.95....
Aaron
Old May 24, 2005 | 02:32 PM
DiabloGT's Avatar
what would you type in on summit? i typed in altenator cover, and it was only the old model altenators, and which one is the part number for the $80 one you seen
Old May 24, 2005 | 05:07 PM
jsk96z28's Avatar
Cut an inch off of mine on the MAF side, no problems...
Aaron
Old May 24, 2005 | 07:05 PM
fastcamz28's Avatar
thanks
His name is Tom Coker (if I remember correctly).
tom@mralternator.com
Old May 24, 2005 | 10:15 PM
got_hp?'s Avatar
i had the same prob, i cut 1/2 inch off the maf side of my CAI and it fit fine. did not wanna cut that purdy trickflow.
Old May 25, 2005 | 02:54 PM
DiabloGT's Avatar
you dont see the cut do you? will it be covered from that rubber part?
Old May 25, 2005 | 07:18 PM
jsk96z28's Avatar
Nope, its covered.
Old May 30, 2005 | 05:40 PM
narlydude's Avatar
beautifulllll
