Problems with running a '95 tranny in a '94 OBD1 Car
Old Jun 30, 2005 | 01:38 PM
EODUSMCR's Avatar
I was told that this can't be done without certain changes to my PCM and adding of some type of wire to the tranny to get the TC to lock. But whenever I drive the car it feels like it's locking but, when I try and get on the rpms will jump to 6500 when I give it more than 1/2-3/4 throttle. Anyone know what the problem is? Also where can I find the scematic for the wiring?
Old Jun 30, 2005 | 02:59 PM
white/blackss's Avatar
Re: Problems with running a '95 tranny in a '94 OBD1 Car
95 IS OBD1 ALSO. I DONT SEE WHAT THE DIFFERENCE WOULD BE BUT MAYBE THERE IS SOME THINGS DIFFERENT.
TRY SHOEBOX`S SITE, HE HAS ALOT OF GREAT WIRING DIAGRAMS AND INFO ON THESE PROJECTS.
I THINK IT`S WWW.SHBOX.COM
GOOD LUCK!
Old Jun 30, 2005 | 03:19 PM
96ta(nick)'s Avatar
It is not as bad as me using your Auto pcm in my m6, It runs but no reverse and anything over 3k it starts doing all kinds of wierd stuff.
Old Jun 30, 2005 | 11:59 PM
EODUSMCR's Avatar
GOOD LUCK!
Yes I know '95 is also OBD1 but, there is a difference between '94 and '95 tranny's. Bryan from pcmforless said if I want to run the tranny in my '94 I need to re-flash the pcm for a '95 and add a wire from the pcm to the tranny connector which will allow the TC to lock.
Old Jul 1, 2005 | 09:00 AM
That's because the 1995 uses a different way (PWM) to operate the TCC solenoid.
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
