Problem installing injectors?!?!
Old Jun 20, 2003 | 12:43 AM
AlexsZ's Avatar
Bought some Bosch 30# injectors, and in trying to reinstall them back into the fuel rail, I've ran into problems. For some odd reason, they dont seem to sit right and backwards. Meaning: When I have them 'placed' the plug is actually facing the wall of the intake and therefore cant place the connector into it. Its almost as if its reversed. When I looked closely at the injectors, I noticed the lips had different grooves in them.
The yellow is the 'problem' I'm having, that groove is what (or what I think) is causing the problem. Its like two half moons on opposites sides of the injectors and they need to be moved 90 degrees in order for it to fit. I called the company and they said all injectors are the same (LS1, LT1's, TPI's, Mustangs....).
So what am I doing wrong here? I feel like a monkey...
Old Jun 20, 2003 | 03:59 AM
AlexsZ's Avatar
TTT
Old Jun 20, 2003 | 04:54 AM
MZK4252's Avatar
i think thats the way mine loooked, too. Just get it on the right way, then see about getting that clip on there. The clip should fit those, but I'm not sure what your clip looks like. Sorry I can't be more help, but good luck.
Old Jun 20, 2003 | 04:55 AM
m0nk's Avatar
It might be that you are trying to put the clips in the wrong set of grooves. I will try and remember to take a few pictures of my fuel injectors when i get home. I just replaced my 74# with 36# and didnt have any problems.
Old Jun 20, 2003 | 05:27 AM
m0nk's Avatar
Just took a few shots of my injectors, if you want different angles or anything then just post agian and ill get back to you in about 8 hours or so when i wake up.
http://members.aol.com/atomicm0nk/images/injector.jpg
http://members.aol.com/atomicm0nk/images/injecto2.jpg
Old Jun 20, 2003 | 06:52 AM
HungryT/A's Avatar
AlexsZ,
Forget those clips. Many of us run the SVO's without them, without any problems. If you take a close look at the injector seats in the manifold, you'll see there's really no way they can go further in the manifold, so they can't "slip out" of the fuel rail.
I tried to force/push those clips on my SVO's, just to sooth my soul a bit, but it's really not worth the effort IMHO.
Good luck
Old Jun 20, 2003 | 06:55 AM
CANTONRACER's Avatar
I took a razor blade and just made a slot for my injectors.
Old Jun 20, 2003 | 11:45 PM
AlexsZ's Avatar
m0nk
Thanks for taking the time on those pictures....mine look to have different grooves than yours. I'm just gonna slice a groove in the top of the injector to insert the clip....I guess just as a precaution.
Thanks for the info guys, much appreciated!!
Old Jun 21, 2003 | 12:18 AM
ltlhomer's Avatar
You're trying to insert the clip in the wrong spot. The clip goes on the other slot, the one not circled in yellow (the one closer to the o-ring) :-). I just installed my 30# svo's 2 days ago. You can see on monk's pic that he used the same slots as me. And they're right, ya don't need em anyways, just a nice precaution.
Old Jun 21, 2003 | 12:46 AM
m0nk's Avatar
Ill have to agre with homer, your trying to put the clips in the wrong slot, if you can see on my injectors, the slots you circled were not the ones I used
Noenav
Mar 1, 2019 07:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
