pro mag 3/8 rr
Old May 30, 2004 | 09:42 PM
Zeueses 97 RamAir's Avatar
pro mag 3/8 rr
I was wondering whats better going with a 3/8 rr or 7/16 this guy is selling the whole kit new for around 200 dollars. I am going to put a joe.o cam in in a couple of weeks, I know 7/16s is stronger other than that I dont know Thanks.
Old May 30, 2004 | 10:04 PM
Bud M's Avatar
Like you said, a 7/16" stud is stronger and will deflect less under load. If you are going to run real stiff valve springs, stronger studs would be nice but $200 for a set of promags (assuming they are new) would be hard to turn down.
Old May 30, 2004 | 10:11 PM
so what do you think
So what do you think I should do. Honestly Im going to have to think about this a lot thats why I need opinions. I have all mods except cam so what do you think Oh im going to go with comp r springs.
Old May 30, 2004 | 11:44 PM
stereomandan's Avatar
In the long run, which would you rather have: saved $100, or worry about weaker 3/8" studs, and if they will deflect/break under load.
After 1 year, you will never miss the money, but you would always worry about the parts.
Dan
Old May 31, 2004 | 10:50 AM
Bud M's Avatar
With the stock cam I'd run LT4 springs. Less spring pressure = less wear and tear on the valvetrain. In that case 3/8 studs will do fine.
Old May 31, 2004 | 11:02 AM
Yes, but he says that he's putting a Joe O. cam in, in a couple of weeks. I've heard that his ramps are pretty agressive.
Dan
Old May 31, 2004 | 10:13 PM
thats what im afraid of
thats exactly what im worried about.. guys
Old May 31, 2004 | 11:03 PM
Bud M's Avatar
Maybe you should ask Joe what he recommends.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
