pro-gram engineering main caps choice?
Old Jul 19, 2005 | 05:52 PM
djm_e22's Avatar
I am looking at the pro-gram engineering splayed main caps for my 1996 z28 LT1 and was going to get item# SB350C22 with the 22 degree outer bolts and the website is http://www.pro-gram.com/catalog.jsp
The reason I am specifically trying to get this item number is I may be able to get them for a good deal. Will these specific splayed main caps work for my car. Thanks for any help.
Old Jul 19, 2005 | 08:30 PM
NVetro's Avatar
Re: pro-gram engineering main caps choice?
That is the correct part number bud. I am also using those caps (PT number SB350C22) in my new 383 stroker setup. I hear from lots of people that they are VERY good caps, machine shop doing my 383 also liked them. Get'em, have fun
Old Jul 19, 2005 | 09:35 PM
MachinistOne's Avatar
Pro-gram is my choice for main caps, just make sure you use the flat caps so you can move the register point out to the pan rails.
Old Jul 19, 2005 | 10:23 PM
djm_e22's Avatar
Not sure what you mean by flat caps, but is the item number I gave in my first post the flat caps that you are recommending.
Old Jul 19, 2005 | 10:56 PM
SStrokerAce's Avatar
There are stepped and flat caps... unless you are going crazy on the power I would just stick with the stepped caps since they are easier to install.
I'm using a set of these on a motor right now, they make very good caps.
transam_388
Mar 15, 2015 11:53 AM
CARiD
Jan 27, 2015 06:27 AM
The Seer
Nov 24, 2014 07:59 AM
Jul 4, 2005 05:00 PM
