pro comp r lifters
Old May 30, 2003 | 02:28 PM
25thAnnTA's Avatar
pro comp r lifters
will pro comp roller lifters work in my 94 ta with the hot cam kit and stock pushrods? thinkin bout buying a set with a good price but want to make sure i dont need to change anything else? gotta let the guy know by the end of the day-can anyone help me out quickly here? -appreciate the help guys!! : )
Old May 30, 2003 | 03:27 PM
Fastbird93's Avatar
Comp R's will work just fine with your setup. They're a direct swap for the stockers.
Old May 30, 2003 | 03:29 PM
25thAnnTA's Avatar
Thumbs up
hey thanks for the input!! gonna go ahead and buy the set then!!
Old May 30, 2003 | 03:41 PM
snorkelface's Avatar
The Comp R listers are the ones that are supposed to act like a solid roller above 2500RPMs or something, right? I was wondering how good that setup would be compared to going to full solid roller? Any comments?
Old May 30, 2003 | 04:03 PM
25thAnnTA's Avatar
well, whatdya think? picked up the comp r lifters used with 1000 miles and a tci convertor 2800 stall for 350-was it a decent deal?? (that convertor in my car currently was advertised at 2600 but wont stall anywhere near it)
how is it that these lifters take on the characteristics of a solid lifter at higher rpm though??? havent heard that.
Old May 30, 2003 | 04:13 PM
I thought it was these lifters that I heard do this, but I may be wrong. I don't know the techcical aspect of their function either.
Old May 30, 2003 | 04:15 PM
Fastbird93's Avatar
They pump up by 1800 rpms. If my thinkings right, they basically fill with oil (pump up) and thus take on the characteristics of a solid roller.
Old May 30, 2003 | 04:23 PM
That sounds right. So you get the efficiency of a solid, without having to adjut them. Does anyone know how well they accomplish this in comparison to a solid?
Old May 30, 2003 | 04:26 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
um.. they will give you none of the benifits of a solid roller. the big thing about comp Rs is they can handle a lot more spring pressure, and thus more agressive hydralic cams.
Old May 30, 2003 | 04:31 PM
Fastbird93's Avatar
I'm taking back what I said. I'm inclined to listen to the quotee.
Old May 30, 2003 | 04:35 PM
Doh! At least now I know so that I won't bother getting these in the future. Living in Cali would prevent me from running a cam aggressive enough to take advantage of these (I think) with the smog *****. What's everyones opinions on these?
Old May 30, 2003 | 09:10 PM
Dave88LX's Avatar
Pumping up with oil...isn't that how ALL hydro lifters work?
Also, last I knew, combinationmotorsports had these Comp R's on sale for $199, not sure if it's still going on. I was trying to find them in Summit but don't know which are the R's. Anyone have a part # ?
Old May 30, 2003 | 09:40 PM
Ai's Avatar
Ai
875-16 is the part number for them, they're called Pro-Magnum HR lifters.
They're just a hydraulic lifter from what I've seen... nothing that's going to make a difference 99% of the time for people. Of course they dont hurt..
Old May 30, 2003 | 09:46 PM
Dave88LX's Avatar
Cool thanks for the PN, I'll check them out! I need new lifters anyways. I took out a couple lifters (flat spots on the rollers) and a couple cam lobes when I spun a rod bearing.
13qtr
Oct 28, 2016 08:11 PM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
