Priming the oil pump.
Old Dec 10, 2005 | 04:34 PM
supercharged87's Avatar
I'm wondering, I want to drop my motor in with the intake on, so I want to prime the oil pump on the stand. My question is, if I prime the motor one day and start it up the next day is that okay? The motor is brand new. Thanks in advance.
Old Dec 10, 2005 | 06:16 PM
1racerdude's Avatar
Re: Priming the oil pump.
It would be the same if it had 20,000 miles on it and ya brought it home and shut it off one night and cranked it the next morning,
Old Dec 10, 2005 | 06:39 PM
Lonnie Pavtis's Avatar
In other words, it would have oil pressure as fast as possible, but you would wash off any assembly lube that was put on the bearings by priming the pump.
I generally test the pump for proper pressure before installation .... used an old main cap with a pressure gauge attached to it. Not necessary, but good piece of mind.
After installation, I then spin (prime) the pump until oil comes out the filter boss. Then I fill the filter completely with oil before installing it. Then I install the intake (after installing the distributor stub).
Within a few cranks (by the time the engine fires) the oil pressure gauge is coming up. The assembly lube will protect it for the first few cranks, until the oil takes over.
Old Dec 10, 2005 | 07:13 PM
walt355's Avatar
The last 2 times Ive put mine in Ive had the plugs out, yanked the fuel pump fuse and cranked it over. I also installed a mechanical guage so I could see when I had pressure built up.
HectorM52
Jul 30, 2017 11:46 AM
FredM
Jun 5, 2015 05:45 AM
KYWes
Apr 15, 2015 07:11 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
