priming lt1 oil pump
Old Jul 8, 2008 | 10:51 PM
z2ws6's Avatar
how do you go about priming an lt1 pump in the car before you start it the first time???
Old Jul 8, 2008 | 11:41 PM
You use an SBC priming tool on a drill while the intake is off (oil pump drive removed).
Old Jul 9, 2008 | 03:34 AM
SS RRR's Avatar
If the engine is in the car you need a right angle drill and then follow what shoebox said. Make sure the drill is on a high rpm setting.
Depending on the drill you may not see oil come up through the pushrods/rockers. Prime it for a few minutes and you may see it trickle to a few of them. Just make sure before you start it all your contact surfaces on your valvetrain has a generous portion of assy. lube or equiv. on it. That includes guideplates as well so you don't get a "squeak" sound once fired up.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Aug 8, 2002 02:53 PM
Captain Kirk
Jul 26, 2002 06:39 PM
