priming a freshly built engine???
I'm helping a buddy rebuild his motor and would like to know the best way to prime the engine (with oil) for the first startup so that we don't damage the new engine.
Should we use one of those oil pump power drill attachments?
Isn't there a fuse you can pull that will let you turn over but not start the car? Should we pull that fuse and turn the engine over for a minute to get oil pumped throughout the engine, then put the fuse in and fire it up?
I just primed mine yesterday with the primer tool. Pretty cool. I hooked up my ohmmeter to the oil pressure sending unit and calculated that I was getting at least 50 psi of pressure just with the rechargeable drill at low speed. Flushed out all the air pockets and ran it numerous times to try to be sure oil would get to all the bearings.
If you have to do it by using the starter, pull the PCM BATT fuse.
The main idea behind priming a fresh engine is that you want to get oil pumped throughout all of the passages and into all of the bearing surfaces before anything starts to move. Using a priming shaft and drill motor is the best solution (by the way Shoebox, do you a have to have the intake off to use the tool on our motors?) Second best will be with plugs removed (minimal load on bearings) and third best is with ignition disabled. All that said, if you prelubed all of the parts as you assembled your engine you will be fine whichever method you choose.
Originally posted by gb95zconv
Yes you do.
A pressurized cannister would be the best method because of the intake thing.
Yes you do.
Originally posted by Serene
...use a drill and old distributor shaft with the gear taken off
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
