Preparing to Fix Intake Gasket
Old Jan 2, 2005 | 05:28 PM
Brian89T's Avatar
Question Preparing to Fix Intake Gasket
I've seen some post recommending different types of RTV/sealants. Could anyone tell me which is the best to use? Also is it better to order the gasket from GM or an aftermarket supplier?
Brian
Old Jan 2, 2005 | 05:38 PM
NOMAD's Avatar
Re: Preparing to Fix Intake Gasket
I have good luck with FelPro intake gaskets and regular copper RTV.
-Shannon
Old Jan 2, 2005 | 05:39 PM
brandboZ28's Avatar
-Shannon
I use the FlePro Gaskets and Permatex Ultra Copper too.
Old Jan 2, 2005 | 05:48 PM
ibanez6rg's Avatar
I've used Fel-Pro gaskets with either blue or black RTV.
Old Jan 2, 2005 | 05:52 PM
thermwood1's Avatar
I like the Ultra Copper also. It's safe for most sensors and is also a high heat sealant.
Old Jan 2, 2005 | 07:18 PM
Fuels94TA's Avatar
GM and Fel-Pro are about the most common sets that are use the most. GM will supply it's own RTV sealant with the kit, I don't know if fel-pro does? The key is to lay a good bead on a clean surface.
Old Jan 2, 2005 | 07:42 PM
ibanez6rg's Avatar
Also "scored" the surfaces where RTV was placed. Help the RTV to grip on something. Both on the intake and block.
Old Jan 2, 2005 | 10:50 PM
brandboZ28's Avatar
Felpro does as well.
Old Jan 3, 2005 | 09:15 AM
Quick96Z's Avatar
the stuff that felpro and gm supply is more or less permatex black
trav
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
MislMan
Jul 19, 2002 11:41 AM
