Pre-cam and Post-cam lt1 vids
Old Jul 16, 2008 | 08:02 AM
ZL1modified's Avatar
Got the cam and torque converter all broke in now and it's time to have some fun...
Pre-cam, would consistantly run 13.1@103
post-cam, not sure what it will run but i'm hoping for 12's
EDIT: check out mod list below--> new mods are highlighted blue...
i apologize for just having crappy cell vids... tell me what you think... i smell 12's!
MODS:
Engine:
- Electric Water Pump
- Comp 10308-1 valve spring kit
- Comp Pro-Mag 1.6 NSA Roller Rockers
- Lingenfelter cold air intake ditched the moroso cai
- ARP fuel pressure regulator
- Crane 227 cam 210/224 duration, .510/.552 lift, 112 lsa
- LS7 lifters
- Cloyes double roller timing chain
- 7.200 pushrods (almost midlift)
- 30# SVO fuel injectors
- 1LE intake elbow ditched the vortech elbow
- LT4 valve covers w/cap and pvc breather line
- 160* thermostat
Exhaust:
- Pacesetter Long tubes, coated
- Pacesetter Off Road Y-pipe
- SLP LoudMouth 2 catback system ditched lm1
Transmission:
- Race Built 4L60E
- Yank SS/3200 Stall torque converter
- B&M transmission cooler
Rear:
- LS1 10 bolt with 3:23 ratio gears ditched 3:42's
Chassis & Suspension:
- Spohn Lower Control Arms
- UMI Torque ar with G-force brace and drive shaft safety loop
- Ls1 Splindles calipers and rotors
- UMI subframe connectors
Misc.:
- Removed air conditioning
- Removed ABS system
- Removed the Traction Control System
- Added SLP line lock kit
Tuned by MadZ28.com
Old Jul 16, 2008 | 09:48 AM
kylersaulsbury's Avatar
whats the new setup?
Old Jul 16, 2008 | 10:56 AM
edited post to include mods
Old Jul 16, 2008 | 12:37 PM
MarcR94v6's Avatar
So before you had all the mods but stock cam? Did you do anything to the heads?
I'd say 12's are you're either way.
May I ask why you ditched the vortech elbow? I've got one and I'd like to know if I should keep it. Actually I think I may have a trickflow.
Old Jul 16, 2008 | 12:50 PM
Dave1980's Avatar
sounds like you need more traction now.
reamo04's Avatar
definate improvement
Get some drag radials now and take her to the track
Old Jul 16, 2008 | 01:41 PM
blue 79 Z/28's Avatar
you need 3.73's not backwards from 3.42's. get those 3.23's swapped out. you will prolly lose a tenth with the 3.23's and pick up 2-3 by going to the 3.73's.... traction permitting
Old Jul 16, 2008 | 02:28 PM
Jazsun's Avatar
Easily hit 12's w/ drag radials on a cool day....otherwise traction would be hard to find if your on a stock tire. I have no sound at work...but 2nd or whatever gear it shifts into after you started...pulled way harder in the 2nd vid.
Old Jul 16, 2008 | 02:49 PM
Just a personal preference... i was going for that black factory look... i also think that the metal elbows have too much heatsoak and that the rubber elbow stays cooler...
My future plan is to go with the strange s60 with either 3:56 or 3:91's (if those are options)...
i defenintly want to get some drag radials but they are not cheap... rigth now i am running stock wheels and tires but i do have some 98 c5 wheels that use a very soft rubber that bites real good...
Did you all happen to notice my oil pressure guage? what the hell is up with that?
Old Jul 16, 2008 | 10:19 PM
JakeRobb's Avatar
Super Moderator
Well, it's definitely pulling harder in the "after" video. Whether you can pull off a 12-second run on street tires has yet to be seen.
Old Jul 17, 2008 | 06:57 AM
95z28man's Avatar
Believe it or not, your probably losing HP with a Vortech. I was told by the guy at the dyno that anytime they see one of those on the dyno compared to stock, it always loses close to 10 hp. So you'd be better off going stock, but I think Trickflows are better than stock, so hopefully you have that.
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Chris Ja
Sep 14, 2002 06:10 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Ude-lose
Jul 31, 2002 02:11 AM
