Power Window Motor Questions?
My passenger side window moves slow up and down.I figure that it's going bad. so i'm going to replace both of them at the same time.My questions are....
(1) Where else besides Autozone(45.00/piece) can i get them?
(2) Will they be faster than the factory motors?
(3) Any info on how to change them? Previous install websites,etc. Thanks
Yup, thats the motor. I also got the lifetiem warrenty rebuilt for my drivers side. My passenger side is MUCH slower now. I've had the rebuilt for a year and it hasn't slowed down yet. Swapping it a second time with the lifetime warrenty will be real easy once you have the holes drilled. Much cheaper option than a new gm one.
http://csce.uark.edu/~jgbertr/rb/adj_window
I just had deja vu when i saw shoeboxes link because i just posted this one in another thread. there is probably a linke to that site from the one shoebox posted since it's the same guy. That has more to do with alignment which you'll also want to get right.
yup, that's your window motor overheating when it stops then cooling off and going up the rest of the way. mine started out like that and it got to the point where it took 20 minutes of stop and go to get the window up. the ones at autozone are the best deal, and they come with a life time warranty. shoebox's guide is the best and saved me alot of trouble. it seems faster than the factory motor.....
Originally posted by 94formulabz
is that actaully shoebox's site??? if so thanks man, its great when people take the time to help others out with great info like that!
