Power window fix - not motor
Just thought I would share in case someone else experiences this.
My passenger window started acting oddly. Goes down about half an inch then sticks. Won't go up or down from either switch. Open and close the door and it works fine untill you close the window all the way (up) then the same thing.
So, I had some time last night, used Shoebox's excellent instructions to take the door apart
I was hoping to find a bad connection, getting GM parts down here quickly is a challenge. Anyway, found the culprit: The side mirror pod that has the 'channel' for the leading edge of the glass was completely loose! It was causing the glass to bind in the channel when going down. So adjusted that and tightened it down now everything is OK.
So if your power window seems to bind, apart from inspecting the actuator remember to check the mirror pod.
Dutchie
'96 Z28
. I was hoping to find a bad connection, getting GM parts down here quickly is a challenge. Anyway, found the culprit: The side mirror pod that has the 'channel' for the leading edge of the glass was completely loose! It was causing the glass to bind in the channel when going down. So adjusted that and tightened it down now everything is OK.
Dutchie
'96 Z28
Originally posted by 1995ta
Mine gets stuck going up. It will go a couple inches, then stop. You have to wait a minute or so, then it will move a couple more inches. You gotta keep doing it until its all the way up. Whats wrong?
