Power steering fluid
Old Oct 8, 2004 | 04:04 PM
pHEnomIC's Avatar
How do i change the power steering fluid, and is it important to do? Its very possible that my car has the original fluid in it. Is there anything else i should do to my steering?
Old Oct 8, 2004 | 04:24 PM
mike85gn's Avatar
Re: Power steering fluid
My GN still has original power steering fluid in it, and it's almost 20 years old. It still steers, too.
Old Oct 16, 2004 | 01:56 AM
pHEnomIC's Avatar
I am gonna do it for the heck of it, what should i use in it? Do i just use Dexron 3?
Old Oct 16, 2004 | 09:04 AM
n2ceptor's Avatar
They make power steering fluid..... Back in the day, you could use trans fluid, but it is not recommended for todays pumps....
Old Oct 16, 2004 | 09:44 AM
Mtrhds94Z's Avatar
Shoebox page has a good writeup on bleeding it[which you'll have to do after refilling it..]
I took the reservoir off and cleaned it, rigged an extension on the return hose, and started the car for a FEW secs to drain it, have a way to control the HIGH pressure outflow[ask how I know.. it shot out of the container I had the hose end in, and sprayed all over, doing it alone.. make sure you wedge the hose in the container]
Then refill it, and bleed it.. it took some time to work all the bubbles out[ you can feel that.. it 'vibrates' when you turn]
I used Valvoline Synpower Synthetic Blend.. Pep Boys etc comes in plastic quarts that look like the oil containers..
Did it NEED it? Probably not, but I think freshening it after 10 years a good idea.. The old stuff was pretty dirty..
Old Oct 16, 2004 | 01:20 PM
pHEnomIC's Avatar
Thanks for all the useful help, how many quarts do i need to get it properly filled?
Old Oct 16, 2004 | 07:02 PM
Mtrhds94Z's Avatar
Capacity is 1.5 pts..
So a quart fills it..
I got 2 quarts and used one to flush it also[forgot to add that up in the other post]what I did was pump the old out[start car but don't run that pump DRY for long!Try not to run it dry at all if you can] then refill with fresh, then do it again..
Then clean the reservoir [Brakleen etc] and then refill it, and then bleed it.. top off as needed..
mspennyhughes
Mar 1, 2015 03:50 PM
