power loss possible 1/4 times
i just installed 1.6 SA roller rockers in my 97z28,it feels like i lost a little power since, is it possible to lose power if i didnt installed them correctly? my mods are cc503,ported intake,cai,MT drag radials,1.6 sa rockers,spec3,lt4 km,madz28 tune,airfoil,stock 3:42s,lca,some weight reductions, my best time was 13.2 @ 106 with a bad 2.2 ft im not concern with my 60ft but shouldnt i be trapping higher than that? temp was 88*,humidity 17% and elevation 1200,any ideas i'll aprecciate thanks?
and more lift does not always mean more power, you car may respons better to the 1.5's.. try some diffrent combos..put the 1.5 on the inake and 1.6 on ehaust and vice versa. its going to be very hard to determin anything by how it feels.. get on a dyno.
What valve springs are you running? If they're the stockers, that'll be your most likely problem. They can barely handle the stock cam with 1.5 rockers, let alone anything else.
what is your preload set at??? i would set to 1/4 past zero lash and work on that 60' and i think you will be happy...
i assume that you have an m6 based on your stock gear ratio... but i definently think you should trap faster...
i trapped 13.18@103 1.90 60' with bolt ons and an a4 with 91 degrees w/ 90% humidity and 1250' above sea level...
Now you do know there is a proceedure to adj. the valves don't you? Makeing sure they are on the "HEAL" base of the cam, not the lobe, you can do it with the piston at TDC on each cylinder, then adjust those valves, but there is a better method, just don't quite remember how it went
Its been awhile sence i've adj. valves, i used to run a solid flat tappet. Maybe someone will chime in!!Its like (use a remote starter button), as your looking at the rockers on that cyl., As the intake valve "starts" opening "adjust the exhaust" & as the exhaust valves "starts" to close, "adjust the intake" or something like that, i've slept sence then lol.
